22G1034 Remote Reverse Idler Gear Heavily Worn
engine
Best Answer nicklouse , 07 December 2020 - 12:20 AM
Just a thought here. I might just have one of those.
Go to the full post
4 replies to this topic
#1 MiNiKiN
MiNiKiN
  • 223 posts
Posted 06 December 2020 - 11:54 AM
Hi beeps, help needed.
It seems the gearbox had a pretty hard live in my 20k mls (!) Inno, with a (previously not so well welded) cracked casing. Due to impact through the Inno sump guard
Almost every bearing with spalling or broken cages. The layshaft worn out, a broken final drive gear bolt just loosely held in place by the tab-washer and a reverse gear that looks like some rodent’s been nibbling on it.
Attached File  IMG_8243.jpg   29.8K   16 downloads
I am very unwilling to re-use this reverse idler, but haven't found a replacement at the usual suspects - they are 'N.L.A' at MS and out-of-stock at Minisport.
Options:
  • find a used one in good nick - has anyone here got one spare?
  • going the OTT route of metal spraying and regrinding the existing one.
What is your opinion and experience? Is this wear something not so unusual? Any good advice wellcome as this currently is a bit of a spanner in the works of the gearbox rebuild.
#2 nicklouse
  • 19,067 posts
Posted 06 December 2020 - 02:19 PM
Guessworks is the place to ask. And to be honest where do you think it is worn? Hard to see in that pic.
#3 Spider
  • 15,880 posts
Posted 06 December 2020 - 06:45 PM
Nick, if you look at the teeth on the upper side of the Pic, it is a bit hard to see, but they are worn right through the case.
#4 nicklouse
  • 19,067 posts
Posted 06 December 2020 - 07:26 PM
Oh yes. Zoomed in and it’s like cheese.
#5 nicklouse
  • 19,067 posts
Posted 07 December 2020 - 12:20 AM   Best Answer
