Hello all 👋🏾. Im brand new to The forum and amazed of the helpfulness and knowledge on here. Great community!!
I currently own a 2000 JDM mini that was converted from auto to a manual (friend had a spare manual block i was able to use) the car is running okay but the coolant temperature only seems to rise slighty over the blue line. And seems to run a tad rich as the ECU thinks its cold. Even after a 30/40 minute drive in warm weather the needle only sits above blue line. At idle its 1100/1200 rpm.
The car used to have air con but since the engine replacement it wasnt re-installed.
I have just had the CTS replaced aswell as a system flush and a new 88° thermostat.
But still the problem persists. Anything else i can check?? Im not mechanic but dont mind taking on small tasks lol.
Coolant Temperature Gauge Not Rising / Stuck In Cold Loop
Marksingh90
, May 31 2022 06:13 PM
engine electrical
3 replies to this topic
Posted 31 May 2022 - 06:13 PM
Posted 31 May 2022 - 11:06 PM
Have you used your old water temperature sensor or the one from the replacement engine, is the fuel gauge reading properly ? Did you use the thermostat from your original engine or the one from the replacement engine ? Lots of questions before you can get any answers....welcome to TMF by the way.
Allan
Allan
Posted 01 June 2022 - 08:54 AM
Check what the actual temp is. Most likely incorrect sender or incorrect wiring.
Posted 01 June 2022 - 12:35 PM
[quote name="Aly-g" post="3722005" timestamp="1654038360"]
Thankyou for the welcome and reply. The old engine was from a carburetor verson and my injection unit has gone onto it. There is an old coolant temp sensor still in the block but no wires connected to it. My CTS is on the manifold like all SPI cars. The fuel gauge works fine aswell as all other dash clocks. The temp gauge does lift but only slighty over blue my millimeters and stays there. Ive have noticed a sooty exhaust tip and bad economy. Aswell as idle at around 1200rpm.
Could it be that i use my original ecu that was originally for a automatic transmission??
I used the same thermostat the car always had but changed it last week as thought it may be the culprit. (New 88° And new CTS fitted)
But problem still seems to persist. My brothers 98 cooper warmed to temp within 10 mins.
Maybe the lambda sensor is clogged and failed??
(I haven’t got a diagnostic kit to Check that)
Also tagged with one or more of these keywords: engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
