1973 Upgraded To A+ Dizzy Wiring
electrical engine
1 reply to this topic
#1 Beanmini73
Beanmini73
    Starting My Mini Up
  • 1 posts
Posted 03 July 2022 - 11:13 AM
I am in middle of fitting an a+ engine into my mini 1000 (1973)…
I have bought full new 59D accuspark kit, my engine is turning over, I am getting fuel and the timing is right however I don’t seem to be getting any spark, I suspect may dizzy wiring is maybe not correct…
I have tested with test lamp and I am getting power to the coil with ignition turned on….
I have -
black wire from dizzy going to white/black from loom
red wire from dizzy going to + on coil
white wire from loom going to + on coil
white/black wire from loom to - on coil
#2 sonscar
sonscar
  • 3,000 posts
Posted 03 July 2022 - 12:36 PM
I would remove the white black wires and insulate them.The red dissy goes to the white and positive of coil.The black goes to the negative of the coil.There should be instructions incorrect connection can destroy the electronics immediately.Go carefully.The black white wires go to the points and tacho if fitted.Steve..
Also tagged with one or more of these keywords: electrical, engine
