The failure mode is usually push clutch pedal and plunger goes in and sticks,causing the pedal to be permanently hard.Penetrant and working round and round in small circular movements can release it.Steve..
16 replies to this topic
#16
Posted 28 July 2026 - 05:20 PM
#17
Posted 29 July 2026 - 11:58 AM
Thanks all. Got good proper penetrating oil. Got a spanner on the plunger and as sonscar said, moved it back and forth in very small movements and it popped right out. Not even a single swear used.
Time to give it a service, a bit of a tune and sort the brakes and it should be close.
Thanks again
Thanks again
Mini Technical Sections →
Problems, Questions and Technical →
Engine Surging Then StallingStarted by Adge456 , Yesterday, 04:16 PM |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
Main & Be Bearing AssemblyStarted by RCrossley , 11 Jul 2026 |
Head Gasket Or Tappet Cover Oil LeakStarted by crbeasley01 , 25 Jun 2026 |
Clutch Housing Wear From FlywheelStarted by Jackrabbit18 , 22 Jun 2026 |
