Flubber!
779 replies to this topic
#691 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 23 March 2008 - 05:11 PM
that must have been well tight or did you put it in back to front? has it done any damage to the crank?
#692 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 23 March 2008 - 05:19 PM
As i said, it hasn't touched the crank, thankfully :X
It enver felt tight going in, and I still had end float after...
#693 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 23 March 2008 - 06:39 PM
what was the end float? when you step on the clutch did it feel ruff (rough) or make any wird noises?
Edited by Rosslin Racing, 23 March 2008 - 06:40 PM.
#694 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 23 March 2008 - 06:46 PM
4 thou...
I am thinking maybe I should of made it a bit more, maybe 5 thou, due to me using a Orange diaphram.
When I first built the engine, I though the clutch felt heavy, but I got reasured that, its how a Orange plate feels. When it came to driving for the first time, the clutch felt "juddery" but then, I've always thought pre-verto clutchs were either on or off....
But other than that, all felt fine, drove ok etc...
#695 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 23 March 2008 - 07:07 PM
Hmmmm you are talking Inch? is that more than 0.127mm? it should be between 0.025 to 0.127mm small bore
and if its 1275 after 1990 it should be 0.051 to 0.076mm and Vizard says on small bore go 2-3 thou over top limit and 4-5 thou on big bore thats Inch for high reving motors. so what is std? i could go and look but its snowing!
Edited by Rosslin Racing, 24 March 2008 - 11:06 AM.
#696 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 23 March 2008 - 07:13 PM
Well after fitting the top thrusts only, I can get a 4 thou (0.004") Feeler gauge down the side on one of the thusts when the crank is being pushed over to the one side.
As I read it in the Haynes, this means I have 4thou end float?
I am using a brand new crank, so it 0/0 and thrusts as standard. I am using "std" AE Thrusts, so I guess standard must be 4thou?
#697 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 24 March 2008 - 12:15 PM
the way you have measured sounds ok, what I think is you have quoted inch from your haynes, is it the light blue book? I looked in the dark blue book which is later and that quotes only in MM you said you have a new crank so its a cam numbered crank? so you also have a diffrent tolerance to the older crank type,
maybe that is the problem combined with the uprated clutch.
I would get those yellow poly rubbish engine mounts changed. dont live long at all!!
Edited by Rosslin Racing, 24 March 2008 - 12:19 PM.
#698 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 24 March 2008 - 02:57 PM
Engine mounts?
There engine steadies, and I've been running them for years, and never really had one die....
Yeh the crank is an A+ crank, which is a CAM 6454 or something like that.
I have a few books, light blue, dark blue, green and a purple one somewhere. I have been quoted to use 0.004" by Nick Swift, Simon@morspeed, and Minispares... but I can't help thinking, its going to happen again :thumbsup:
#699 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 24 March 2008 - 04:14 PM
dog, with the centre cap fitted and no thrusts in, are both faces flush with each other? just make sure the cap is the same size as the bearing holder bit on the block.
I don't think I explained that very well :thumbsup:
#700 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 24 March 2008 - 04:55 PM
eh?
#701 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 24 March 2008 - 05:18 PM
[quote name='Dog' date='Mar 24 2008, 03:57 PM' post='898467']
Engine mounts?
Thank you thats what I meant. I had some for one race and that was it bin time.
The measurement is correct, your in the tolerance, something else is not, did you put it in back to front?
just looked at the photo again looks as if it spun as that is not poss you must have put it in the wrong way. it can happen.
Edited by Rosslin Racing, 24 March 2008 - 05:21 PM.
#702 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 24 March 2008 - 05:20 PM
Only thing I can think of is the primary transfer gear thurst?
As i am checking the end float, with no transfer gears on if I need transfer gears on to measure the gap, can someone explain how I would go about doing this?
#703 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 24 March 2008 - 06:01 PM
yes you did, if the main cap is not correctly postioned for example its turned around this may have an effect.
I would check that Dog. you know which way round the main cap should be?
#704 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 24 March 2008 - 06:06 PM
ahhhh its just clicked now what you meant...
When i buint it orginally, they were flush.
#705 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 24 March 2008 - 06:14 PM
so have you put it all back together now?
