Project Wombie - 96 Sprite With A Split Identity
roundnose
87 replies to this topic
#31 MrElliott
MrElliott
  • 419 posts
  • Local Club: Box Hill Mini Club
Posted 19 December 2014 - 09:37 PM
loving it! wish i had put more sound deadening on my roof when i did my car. it would have quietened the bangs as my head hits it down a bumpy road
#32 Richie83
Richie83
  • 1,495 posts
Posted 19 December 2014 - 09:51 PM
The recommended coverage was 50%. I decided on 80% with the silent coat and it produced a dull thud now. Not that I have a head hitting problem at 5 ft 6 😂
#33 Richie83
Richie83
  • 1,495 posts
Posted 05 January 2015 - 08:37 PM
Getting very close now. The new grille is on with buttons for quick access:
7119EEFD-52C6-4D68-838A-8A1A5E6D5F29_zps
As are the arches, doors, windows etc:
D4ABB7FB-30AC-491F-8C15-FF4491C814F1_zps
9F5490E4-1C2D-4476-BDE7-D9389BB34610_zps
85E99D02-451A-41A6-9C7C-178001B2EAA2_zps
It looks very dusty in these photos. So I'll get more once we get a little closer:
15C376FF-5CE0-4A31-95D4-F5D217EE7D7A_zps
Next:
- apply Bilt Hamber UC underneath
- do the box sills, doors efc with S50
- finish headliner (wrong c pillars were supplied so have to take windows out again)
- install door cards and trim for journey home
You'll note that the bonnet also has an unusual amount of curve on it. This could be because the bonnet isn't orginal, or the MiniVation hinges (or a combo). Will need to look into this further.
#34 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 05 January 2015 - 09:20 PM
Looking Good! Bonnet curve could also be down to the scuttle replacement too
#35 Richie83
Richie83
  • 1,495 posts
Posted 18 January 2015 - 08:48 PM
Got the mini back today. Forgot how small it looks in comparison to other cars. The drive home was ace.
D6416AE1-D817-4930-A715-FD6B32838A0C_zps
Next up:
- seats out
- clean up
- deadening
- closed cell foam
- wiring
- carpets
Etc. More photos to come of the completed bodywork.
#36 Richie83
Richie83
  • 1,495 posts
Posted 20 January 2015 - 10:57 PM
As part of the build we fitted brand new red dot cones and KYB dampers all round, as well as genuine hi-los. Visually this isn't all that exciting, but I can honestly say that the ride is a million times better. It irons out the road now (as much as a mini can) and still handles and holds beautifully. Highly recommended.
#37 Richie83
Richie83
  • 1,495 posts
Posted 24 January 2015 - 08:10 PM
Made a good start on the interior today. Tested the central locking, took off the lower dash rail and removed the centre switches (a pig of a job) to make way for Savage switches. A few things have also arrived this week, which give a taste of things to come:
281EAB4E-4E2B-4FB9-8DEC-31389189F171_zps
E5DDBF5D-3B27-41FD-A6F7-746906927BEF_zps
2B818861-2EF8-4880-87EC-0B044765F1FC_zps
I also removed the 2 clock binacle and tested my magnolia ones. Works a treat, even with the updated LED bulbs. More photos to follow.
Edited by Richie83, 24 January 2015 - 08:13 PM.
#38 Richie83
Richie83
  • 1,495 posts
Posted 28 January 2015 - 07:42 PM
Today I set about covering my bottom dash rail. I have opted for a suede like material:
Trim fix was used as its heat resistant. Here's the tacky up faze:
547EB21E-E1AD-4D84-8377-CD6E5BB989CF_zps
#39 Richie83
Richie83
  • 1,495 posts
Posted 28 January 2015 - 07:43 PM
Managed to get a double post. So will edit and continue here. This is how the bottom dash rail came out, not 'trimmer' perfect but I felt I'd done a good job:
9C4B32A4-CB40-4EB7-9560-AE253A7BE676_zps
6AC6EA79-F0CE-4E26-BBC8-2E4203579E01_zps
The top dash rail is trimmed in the same stuff with Tweeters mounted on it. I'll get some better photos ones the dash goes in.
Edited by Richie83, 28 January 2015 - 07:46 PM.
#40 Rocket.
Rocket.
  • 1,444 posts
Posted 28 January 2015 - 08:58 PM
Nice work !
#41 Tata Steva
Tata Steva
  • 19 posts
Posted 28 January 2015 - 09:05 PM
Looking forward to feedback on those Savage kit... Looks great so far!
#42 Richie83
Richie83
  • 1,495 posts
Posted 11 February 2015 - 09:05 PM
Okay, so a couple of weekends ago I set about deadening the interior. But first I had to tidy up the loom:
41B03096-EEB0-4620-86B3-BD49B0AA76D8_zps
I used some Tessa loom tape:
8CF472D8-7B77-4EA9-858B-3000DF567E2D_zps
Next I painted the floor with Hammerite (not pictured) and laid down some SilentCoat (Not full Ruckus, but more than the recommended dose):
92B585BB-F689-4E0E-B242-13B20C1CA99F_zps
I then took some time to plan out and lay down some 8mm closed cell foam:
0C8E6DEE-8D3F-4222-9018-B0EABF93A916_zps
back:
E1D99555-76DB-4AE8-83D0-7C7AA07B0DE5_zps
And then some Cloud 9 underlay (front to do next):
D6469B21-1D8B-46CE-AA93-B1DCA96E9D90_zps
#43 Richie83
Richie83
  • 1,495 posts
Posted 11 February 2015 - 09:06 PM
The following weekend:
Installed lower dash rail:
D12D4FE5-7142-481A-86F5-4824CF3E8178_zps
A shot of my swanky new headliner from Optimise Automotive:
4BFAC528-D7B7-4CBE-86F7-70DA1279EC0D_zps
Next I need to finish the underlay, take up to lay cables for Amp/speakers and fit Newton Carpets.
#44 Richie83
Richie83
  • 1,495 posts
Posted 22 February 2015 - 07:59 PM
Okay so I've been busy getting things sorted for the ICE. Bought a new headunit, two Genesis amps and 4 JL subs to go with my Focal components. I've ran all the cable for this install and am drawing up plans for a nifty under bench Sub enclosure.
I've also installed Savage Switches:
13CA27AB-0A72-4C7C-93B2-49D211849D86_zps
They are wired to come on with sidelights:
7C4F5CDC-A410-40FF-BFB1-C25DD9EF6C9E_zps
Edited by Richie83, 22 February 2015 - 08:02 PM.
#45 Mini_Matt
Mini_Matt
  • 96 posts
Posted 03 March 2015 - 10:58 AM
I like what you have done the dash rails. I was also thinking of doing this. Just wondered, do you remove the old covering or cover straight over the top?
by the way love the button switches.
