I wonder, does that bonnet improve the breathing of the engine? Also very nice work so far :)
#61
Posted 26 January 2015 - 08:00 PM
#62
Posted 26 January 2015 - 08:14 PM
#63
Posted 26 January 2015 - 08:21 PM
Guess then it makes sense, if it will give some bonus performance that can only be a good thing. Though I would fit some kind of meshing or grille so that the shiny rocker cover and nice paint work don't get damaged :)
#64
Posted 26 January 2015 - 08:28 PM
#65
Posted 26 January 2015 - 08:33 PM
Yeah you don't want to spoil the clean look that you are going for.
#67
Posted 27 January 2015 - 10:01 PM
#69
Posted 28 January 2015 - 06:37 PM
The engine bay looks pretty clean. Are you going with the body colour or something different?
#70
Posted 29 January 2015 - 07:55 AM
believed it was actually worse than this, so im happy :)
i`ts going to be painted black, black will look good no matter what color I decide for exterior color, i think.
#71
Posted 29 January 2015 - 08:59 AM
Yes that is true and it will contrast well with the engine colour scheme
#74
Posted 30 January 2015 - 04:26 PM
Hi, great looking mini and also great progress. BUT !!!! are you aware that it has cover sills fitted ?? if so you know the risks but if not your mini has in effect no drainage from the sill box section area and as far as i'm concerned cover sills have ended the life of many minis due to trapping moisture and advancing rust on the outer edge of the floors / inner sills / door steps / subframe mounts and rear bins. Get some waxoyl or something in there and soak it all inside if you're not changing them, but it is best to plan for them to be replaced asap.
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
Projects →
Mini Saloons →
1968 Mk2 Cooper BuildStarted by Minime998 , 15 Sep 2021 roundnose |
