Posted 07 September 2019 - 10:26 AM
Posted 07 September 2019 - 10:42 AM
Simplest would be an inlet manifold air leak. Check hose connections and the slacken and retighten the nuts.
Posted 07 September 2019 - 11:30 AM
I sprayed around the inlet with some carb cleaner but it didn't seem to do anything
Edited by Zak Jones, 07 September 2019 - 11:31 AM.
Posted 07 September 2019 - 10:03 PM
If there's an air leak engine side of the throttle it'll allow proportionally more air in when less air goes through the closing throttle and the manifold vacuum increases.
After market manifold flanges can be a different thickness to the original making it harder to clamp both inlet & exhaust together.
Since it's injection, an air leak on the exhaust side could do similar by affecting the lambda sensor, but you'd probably hear that.
Posted 08 September 2019 - 10:12 AM
Posted 08 September 2019 - 12:30 PM
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
