How To Swap From Servo To Yellow Tag
brakes engine
18 replies to this topic
#1 Mini_Problems_
Mini_Problems_
    Formally known as Cmontgomeryc
  • Just Joined
  • 46 posts
Posted 13 November 2019 - 01:48 PM
I felt it would be useful to explain all the modifications required to change from servo to yellow tag set up.
Why might you want to change to a seemingly obsolete setup? Well in my case I wanted to tidy up the engine bay and install a brake proportioning valve for the rears.
But wait won't this increase you insurance premium I here you cry? After contacting Adrian flux and explaining to them about my flip front and new non servo brakes setup I can confirm that my premium didn't increase. However any brake proportioning valve must be out of reach of the driver.
But won't this make my brakes rubbish? In my experience braking performance is the same (if not a little better thanks to proportioning valve) however the pedal is firmer and you get more "feel". You have to press harder granted but I prefer the way this feels now I've adjusted.
What will I need to make the change?
Yellow tag master cylinder
Early brake pedal (no extension bar)
Old type larger clevis pin
Early type pedal spring
Early type bulkhead mounting plate
Reel of 3/16 copper/nickel pipe
Brake proportioning valve (optional)
Metric unions 12mm and 10mm
Brake fluid 1l
When changing to this setup beware, some unions are metric some are imperial.The connections on the pdwa valve (if you decide to keep it) are both 10mm. The upper connection of the yellow tag is 10mm and the lower is 12mm.
The front split t piece located on the left-hand lower side of the front subframe is 3/8 imperial.
I didn't have to change my front to rear brake line, however you should note that the splitter and the rear should be imperial.
The wildwood proportioning valve I purchased came in a few different union sizes, I picked 10x1 bsf as I had spare 10mm unions, no adapters required!
It can be a fiddly job getting the brake old style brake pedal and spring to all fit. You may have to remove the heater in order to get the clearance to remove the pedal box main shaft.
The reason most choose a proportioning valve when carrying out this modification is due to the rears having a tendancy to lock up. This means you have to swap your rear brake cylinders out for small diameter ones. I decided the valve was easier and gave more tunability.
You can apparently modify a servo type brake pedal by drilling out the rivet and removing the extension. You would then have to drill out the clevis pin hole to make it compatible with an older type clevis pin as required by the yellow tag.
The mounting plate can also be reworked to fit, however for the £20 for a new plate and same again for brake an early pedal I found this easier.
If you are connecting to the pdwa valve from the yellow tag. The top connection of the yellow tag connects to the rh side of pdwa (10mm to 10mm) and the lower union of the yellow tag goes to oh side of the pdwa (12mm to 10mm).
To bleed the system I used a gunsons easy bleed, for £20 seems like a great investment, comes with the correct caps to do brakes and clutch.
The order to bleed the brakes should be rear near side, rear offside, front offside, front offside. The theory being that you should go from furthest away to nearest.
If you are making your own copper/nickel lines as I did, get yourself or borrow a pipe bender and flare tool, try some practice pieces and don't forget to put the unions on before flaring both ends (yes I forgot to do this)
When fitting the new clevis pins use R clips, you will be happy the next time you decide to remove them, I found removing the heater piping made fitting alot easier.
Hopefully this will clear up some of the confusion I experienced doing this.
Much love, connor
#2 splintercat
splintercat
  • 616 posts
Posted 12 January 2021 - 06:57 PM
Brake fluid 1l
Much love, connor
just read this and am doing the same thing however.......I found that the clevis pin on the older style brake pedal is in fact smaller than the standard one? I bought a new smaller one when I got my brake pedal for this very reason as I was going to just weld over the hole in my existing pedal and then re-drill it out but smaller, I managed to get an older brake pedal tho for £15 so used that. You will find that if you have the larger clevis pin and it is sleeved, you can take this sleeve off and the clevis pin is the correct size.....however beware as it is slightly longer and may need shortening. Also agree on the r clips so much easier to use than existing split pins.
#3 Revd
Revd
  • Just Joined
  • 81 posts
Posted 13 January 2021 - 07:33 AM
Good report. During first lockdown I replaced the yellow tag m/c on my 87 Advantage, the clevis pin split pins are a faff but I stuck with them for piece of mind. I also bought a Gunson eezibleed but 4L of brake fluid - nothing worse than running out as you chase down that last air bubble. I’m interested in the proportioning valve, how did you arrive at the right calibration?
#4 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 13 January 2021 - 10:25 AM
Guys this is a 2019 thread, I highly doubt a reply would come from the OP
#5 Dusky
Dusky
  • 5,322 posts
Posted 13 January 2021 - 11:05 AM
Last active 09/01/2021.
#6 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 04 February 2021 - 12:49 PM
to be honest I simply drive at a slow speed and slowly turned it back until the rears no longer locked up. Might sound a bit old-school but it worked fine
#7 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 05 February 2021 - 03:23 PM
Exactly how I do it on the racer, though we are allowed it within reach of the driver so I adjust it depending on how wet the surface is... in a soaking situaiton I have turned off the rears totally
#8 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 11 February 2021 - 01:10 PM
Edited by Mini_Problems_, 11 February 2021 - 01:16 PM.
#9 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 11 February 2021 - 01:15 PM
For all who are interested we now supply yellow tag conversion lines at Helperformance. All our lines are us stainless steel for the braid aswell as the fixture and fittings. two kits, one is for those converting to yellow tag from a servo, the other is for those with yellow tag from manufacture (1988)
#10 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 February 2021 - 01:24 PM
Or make your own and get the bit from Merlin for about £15.
#11 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 11 February 2021 - 02:20 PM
Hmmm, not sure how you got the £15 quid figure. For just one reusable m12 stainless banjo is £51.98 https://www.merlinmo...-g-5092-03-m12c   :ohno:  Also our line are all swaged and orientated for a neat install, not to mention warrantied  :)
#12 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 February 2021 - 04:29 PM
Sorry my bad it wasnt Merlin. It was Car Builder Solutions. £18.60 which was 2 ends and 1 meter of braided hose. How much are yours out of interest?
Edited by Maccmike8, 11 February 2021 - 04:30 PM.
#13 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 11 February 2021 - 04:43 PM
The fitting they supply on there site are zinc plated steel and not stainless. Re-useable fittings and hose has a time and a place, however technology has moved. I came back to this thread to show a neat solution to a problem i encountered. The 18.60 price you have given cant be right as its 16.40 just for 4 zinc plated banjo bolts without washers and delivery on there site. You haven't done your research. Our conversion kit is 2 lines 4 stainless banjos with copper crush washers, in your colour of choice, to the corrects spec, all swaged for 44.98 inc vat and delivery.
#14 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 February 2021 - 05:14 PM
Funny - thats what my receipt says.
#15 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 11 February 2021 - 07:00 PM
Not sure where you got that figure from. We all make mistakes bud
Also tagged with one or more of these keywords: brakes, engine
