Hs4 Mixture Settings
electrical engine
4 replies to this topic
#1 TylerDurden
TylerDurden
    Starting My Mini Up
  • 2 posts
Posted 17 March 2020 - 04:00 PM
Hi,
I am having a problem setting the mixture on my 998cc fitted with a HS4.
The car struggles to start and will not rev without backfiring through the carb.
When i actually get it running the exhaust note sound like a pulse jet, not smooth at all.
Any ideas??
#2 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 17 March 2020 - 04:17 PM
Is the dashpot properly topped up?
#3 Its a min
Its a min
  • 284 posts
Posted 17 March 2020 - 04:38 PM
Have you done any work on the engine/carb?
Backfiring through the carb could be due to a lean mixture. Try and enrich the mixture to see how it goes.but if you've done any work, there may be an air leak or worn spindle /bushes.
Good luck.
Edited by Its a min, 17 March 2020 - 04:39 PM.
#4 blacktulip
blacktulip
  • 6,231 posts
Posted 17 March 2020 - 07:28 PM
Can you confirm if you have modified the 998 at all?
#5 Chris1275gt
Chris1275gt
  • 1,050 posts
Posted 18 March 2020 - 12:02 AM
Buy yourself a colour tune plug and you can get the mixture setting nearly spot on in about a 5 minutes then get it on a rolling road to get it totally sorted. This advice is from experience.
Also tagged with one or more of these keywords: electrical, engine
