Posted 29 May 2020 - 06:44 PM
Changed the oil in my Austin Mini today and out came these pieces of metal.
(https://www.flickr.c...9925@N04/613q81)
Obviously very unusually and quite worrying so wondered if anyone had any ideas what it may be?
Posted 29 May 2020 - 07:27 PM
Has the engine or gearbox been split and rebuilt? What year car is it? I can't think of anything that looks like them pieces from inside the engine or gearbox. I think it's been dropped in and not noticed when being put back together.
Posted 29 May 2020 - 07:35 PM
Looks a bit like the cage from a ball bearing. I'd get a stethoscope or an engine ear/chassis ear on it, sharpish.
Posted 29 May 2020 - 09:02 PM
one piece looks to have had rivets at each end - doesn't look like anything that belongs inside a mini engine/gearbox
Posted 29 May 2020 - 10:30 PM
Posted 29 May 2020 - 11:18 PM
Could be differential bearing cage if you're lucky (relatively). Jack it up and look for backlash, wobble, etc between the inner driveshaft joints.
What's the age of the box? Most A+ cars had plastic cages on the 1st & 3rd motion bearings which'd only leave the diff. Though you can never be sure with a Mini that's changed hands. As could replace diff bearings without major dismantling if you're very lucky it's left over from one that's been replaced. so may be worth investigating before lifting the engine out.
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , Today, 02:47 PM |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
