Engine Fires On Starter, But Dies Immediately On Key Release
engine electrical
9 replies to this topic
#1 Mini_Kit
Mini_Kit
    Starting My Mini Up
  • 2 posts
Posted 28 June 2020 - 02:01 PM
Hi,
Engine is a 998cc from an E plate Classic Mini. Only 30k miles under belt.
Just replaced:
- Full service (plugs, filters, etc)
- Dizzy + cap
- HT leads
- Alternator
- Starter motor
- Radiator + hoses
- Resistive wire with in line resistor
- SU carb cleaned and is operating fine
She has been mothballed for a while prior and we had the engine turning over and firing last summer before the above work was done.
Now when we try to restart her, the engine catches and revs while on the starter motor, however, once the key is release back to position 2, the engine dies. No follow on or attempt to idle.
We figured it might be the ignition switch, so replaced that, but with the same result.
Kind of think it's an electrical problem, but not sure what to check.
Any thoughts out there?
#2 cal844
cal844
  • 9,733 posts
  • Local Club: TFMOC
Posted 28 June 2020 - 08:35 PM
Sounds like the plug leads arent on right, double check the firing order
#3 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 28 June 2020 - 09:02 PM
Check you have power to the coil when the key is in Position II with the panel lights on the dashboard illuminated.
#4 GraemeC
GraemeC
  • 7,472 posts
Posted 28 June 2020 - 09:25 PM
As above - sounds like your missing the main ignition feed to the coil and it’s running on the cranking bypass.
Post some picture of your coil connections.
Edited by GraemeC, 28 June 2020 - 10:18 PM.
#5 dotmatrix
dotmatrix
  • 441 posts
Posted 28 June 2020 - 09:46 PM
pre-engaged starter?
#6 Mini_Kit
Mini_Kit
    Starting My Mini Up
  • 2 posts
Posted 04 July 2020 - 12:59 PM
Lots of head scratching and YouTube videos later, I gave in and got an expert in. (Thxs Bedford Tich!)
After a few umm, ahhs and probing with the magic lamp turns out that nothing was going through the recently fitted ballast. By passed the ballast and she fired up ran fine.
Still unsure what was broken and how it was fixed, but now tuned and runs much better. Will need to revisit the mixture at a later date as running a little rich, but cross that bridge later.
Thxs all for the input.
#7 pete l
pete l
  • 1,529 posts
Posted 06 July 2020 - 07:00 AM
If you bypass the ballast, surely you will burn out the coil.
#8 cal844
cal844
  • 9,733 posts
  • Local Club: TFMOC
Posted 06 July 2020 - 02:00 PM
If the resistor wire is bypassed you'll need to fit a 12v coil.
#9 Ethel
  • 26,761 posts
Posted 06 July 2020 - 05:41 PM
...unless the OP already has a 12v coil, which'd explain why it wouldn't run with a ballasted supply.
#10 cal844
cal844
  • 9,733 posts
  • Local Club: TFMOC
Posted 06 July 2020 - 08:24 PM
Yes, that's quite possible too I suppose
Also tagged with one or more of these keywords: engine, electrical
