I've used the12v and http://www.bcae1.com/ to work out the wiring needs.
12 awg to the sub gives 0.04db loss.
16 awg to the comps gives 0.15db loss.
Using 4awg from battery to dizzy and 8awg from dizzy to amps results in a 0.2v loss which isn't markedly improved by changing the gauge even up to 0awg.
The P4 draws a max 20amp rated 25amp fuse, the Psub 30amp with 2x30amp fuses.
Working from the12volt basing the fuse on the wiring used, I should have 2 x 100amp fuses in the dizzy block.
Is this correct?
I think that 100amp fuses for 12 and 16awg wire will be way to large. According to that website the largest fuse you should use for 12 and 16awg is 20 and 7.5 amps respectively. 12 and 16awg seem way to small!
From what that website says, and my knowledge you should have two 50amp fuses in the distribution block for the 8awg. after that I'm not sure what size wire you would need to feed the dizzy block. 4awg maybe and 80amps maybe, not sure tho.
I've been using 8awg with my genny. (profile sub). at that size the maximum needed would be 50amps. Remember your fusing for the wire not the amp. if the wire was to short at 12 and 16awg the wire would melt before the 100amp fuse would blow.
Edited by freshairmini, 15 October 2012 - 08:40 PM.
