As above really. There are seemingly large chunk of debris on the plug magnet, all really tiny metal parts, only looks like 'hedgehog'!
IMAG0139.jpg 20.05K
73 downloads
Is this a reason for worries?
Posted 20 August 2014 - 08:45 AM
IMAG0139.jpg 20.05K
73 downloads
Posted 20 August 2014 - 08:58 AM
Posted 20 August 2014 - 09:59 AM
I would do an oil change / filter change (as you probably have done due to sump plug out)
I always put some magnets on the outside of the oil filter to trap any fine metal in the oil
as above most mini's have a bit on the magnet - I would say that is pretty normal
it means it's doing its job , most of that came from the gearbox I should imagine
as long as there are no larger bit's - esp non magnetic in the bottom of the oil
ie white metal from the bearings
Edited by sledgehammer, 20 August 2014 - 10:00 AM.
Posted 20 August 2014 - 03:08 PM
thanks for your replies.
Si I assume it is normal picture. There was no more debris in the oil.
Posted 20 August 2014 - 03:56 PM
Posted 20 August 2014 - 04:21 PM
Again it all depends how often you change the oil (this is one of the reasons you should do it regularly) and if you have had any work done like a new box or head skim say id expect a little more than usual but id say thats fairly normal iff it hasn't been done in a while. As sledge said above look for larger chips wear is normal chips are signs the teeth are breaking up.
keep the photo in your mini folder, change the oil, and when you change it again (next year i hope) compare them, the more regular the flushes the less you should see.
Posted 20 August 2014 - 05:28 PM
Mini Technical Sections →
Problems, Questions and Technical →
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
Su Carb Backfiring/spitting FuelStarted by Adge456 , 25 Jul 2026 |
Main & Be Bearing AssemblyStarted by RCrossley , 11 Jul 2026 |
Head Gasket Or Tappet Cover Oil LeakStarted by crbeasley01 , 25 Jun 2026 |
