Mini Won't Start
electrical engine
16 replies to this topic
#1 juddclark
juddclark
  • 11 posts
  • Local Club: TFMOC
Posted 04 November 2020 - 01:47 PM
1994 Mini 35 Edition
So... Mini won't start. Cut out last week and now just turns, like it's not igniting.
No Spark, changed the plugs, dizzy cap, rotor arm, leads, ignition switch and coil and non of these things changed anything.
Tested the positive to the coil and get 12V... not sure if it's intermittent though...
Anybody point me to the next thing to do? Any thing I can test to try and find out where the issue lies?
Edited by juddclark, 04 November 2020 - 01:48 PM.
#2 PACINO
PACINO
  • 821 posts
Posted 04 November 2020 - 01:56 PM
If the distributor is for points and these are bad, it will not start.
#3 Chris1275gt
Chris1275gt
  • 1,053 posts
Have you got petrol after turning over pull a plug and smell.
Edited by Chris1275gt, 04 November 2020 - 01:59 PM.
#4 PACINO
PACINO
  • 821 posts
Posted 04 November 2020 - 01:59 PM
the starter motor turns when you turn the key?
#5 juddclark
juddclark
  • 11 posts
  • Local Club: TFMOC
Posted 04 November 2020 - 02:09 PM
Yeah it's trying to start it's just not going, you can smell fresh petrol and it's got a near full tank so there is enough fuel.
It's got a new cap so the points are brand new...
#6 Chris1275gt
Chris1275gt
  • 1,053 posts
Posted 04 November 2020 - 02:17 PM
Have you checked for a spark at the plug.
#7 FlyingScot
FlyingScot
  • 2,676 posts
Posted 04 November 2020 - 02:21 PM
If it’s a Mini 35 it’s fuel injection ? No points in those....
More likely the crank sensor or the immobiliser (if it has one)
FS
#8 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 04 November 2020 - 03:09 PM
FS
I agree
Edited its a carb car with no immobiliser.
I have a private message thread with the OP checking electrical connections.
Edited by cal844, 04 November 2020 - 03:23 PM.
#9 juddclark
juddclark
  • 11 posts
  • Local Club: TFMOC
Posted 04 November 2020 - 03:22 PM
Its got a carb... one of the last before they went MPI so no, immobiliser
#10 richmondclassicsnorthwales
  • 942 posts
Posted 04 November 2020 - 07:36 PM
There is a small low tension lead in the distributor which is braided - usually brown.
It sits one end under the condenser and the other to the body of the distributor
These do have a tendency to just "Give up the ghost"
Check to see if it is making a circuit - one of these gave up on me once - hence - no starting.
#11 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 04 November 2020 - 08:26 PM
Can you rethink your information please buddy (no anger, in the nicest possible way). it's a 94 reg car with 65D dizzy, it won't have a condenser built into the dizzy like a points unit..
Would it be an idea to bypass the coil feed from the ignition temporarily to rule out the ignition switch and wiring? By running a live wire similar to the Ballast Resistor looms
Edited by cal844, 04 November 2020 - 08:27 PM.
#12 PACINO
PACINO
  • 821 posts
Posted 04 November 2020 - 11:41 PM
Without making anyone angry ... but why is it so difficult for people to post photos when asking for help?
The best thing is to add a engine picture, another of the dizzy and another of the cables or connections.
This makes it easier to help.
Regards, Luis
#13 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 05 November 2020 - 02:19 PM
It could be they are using a mobile .. the mobile interface isn't as clear when adding images. I switch to the FULL version and use the attachment option as I would on a PC
#14 FlyingScot
FlyingScot
  • 2,676 posts
Posted 07 November 2020 - 09:42 PM
Aha sorry wrong end of a different stick... 1994 was a change over unless Cooper.
FS
#15 bpirie1000
bpirie1000
  • Area Managers
  • 2,567 posts
  • Local Club: Amoc
Posted 08 November 2020 - 07:50 AM
Have you been able to set the points again and make sure there is a spark at the points..
The points is the primary spark and if no spark there there will be no spark anywhere else..
If you need help setting or checking the points then let us know we can always assist.
Any other issues you have found or located since?
Also tagged with one or more of these keywords: electrical, engine
