Hif44 Carb Levers
engine
4 replies to this topic
#1 richardsoniscool
richardsoniscool
  • 629 posts
  • Local Club: Bury Mini Club
Posted 21 June 2021 - 08:55 PM
Good evening
A few months ago I bought a HIF44, turns out its from an old Volvo.
At the time I didn't really think about it and planned to rebuilt it, however. i then offered it up to a nice new inlet manifold and abutment plate and realised the choke and throttle levers are on the wrong side and potentially move the wrong way.
Any ideas how I could rectify this issue without buying another HIF44 carb?
I was thinking that maybe I could take the levers from my HS4 (if they fit)  and change the side of the choke and throttle cable clips on the abutment plate , and hoping that could work out.
If anyone know how to jump this hurdle ill be much appreciated, or else ill go shopping for another carb.
thanks,
Mike
#2 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 23 June 2021 - 08:36 AM
Do you have a picture of the carb?
#3 goudoogje
goudoogje
  • Just Joined
  • 94 posts
Posted 23 June 2021 - 11:11 AM
For the throttle you probaly need this part numbers:
LZX1739
AUZX1047
JZX1019
And for the choke:
JZX1609
Ofcourse creating something from bits you already have is cheaper.
#4 goudoogje
goudoogje
  • Just Joined
  • 94 posts
Posted 23 June 2021 - 11:15 AM
And just to add: I changed a Rover HIF44 to mini spec sometime ago, all the bits where a bit expensive, and you need to change the spring, damper and needle to. Buying a carb that is already suited for a mini is probaly cheaper.
#5 richardsoniscool
richardsoniscool
  • 629 posts
Posted 23 June 2021 - 06:17 PM
Thanks for the replies, I've found a few places selling the parts but as you say, very expensive I could buy a second hand carb instead.
A couple pictures below of the Volvo carb.
http://imgur.com/a/XgRtNNF
