Posted 22 June 2021 - 05:20 PM
A local engine machine shop changed them for me and the cam can only be turned by a spanner which they thought was OK. I don't accept this. The cam should turn freely by hand.
Kind regards
Rob
Posted 22 June 2021 - 07:51 PM
Phil.
Posted 22 June 2021 - 08:02 PM
It all depends on which bearings you were supplied with.
some suppliers sell originals that need scraping to fit.
others supply ones that are on size when fitted.
as Phill says yours need cramping to fit.
Posted 22 June 2021 - 08:20 PM
Sorry, I'm not local and can't help with your request here, however;-
,,,,,, changed them for me and the cam can only be turned by a spanner which they thought was OK. I don't accept this. The cam should turn freely by hand.
I gotta wonder what machine shop would think this is OK - regardless of the type of bearings fitted. Running clearance here should be 0.001 to 0.002".
Mini Technical Sections →
Problems, Questions and Technical →
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , Yesterday, 10:15 AM |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
Su Carb Backfiring/spitting FuelStarted by Adge456 , 25 Jul 2026 |
