Am I Missing Something?
engine
16 replies to this topic
#1 rhidmogz
rhidmogz
  • 21 posts
Posted 08 May 2022 - 05:07 PM
Am i missing something??
ive made a rollover jig believe it or not the 3rd one over the years!
but this time if used the front subframes mounts and rear shock mounts as pick up points this time instead of a solid bar through the car but its sitting bowed and impossible to turn and am worried leaving the car on the jig will cause undue stress. to i need to make hangers for the spit? or are my mounts not suitable?
ive already cut the jig down to gwt the centre of gravity lower is the jig itself too high? but it needs to be this tall give or take a few hundred mm so that it can turn the car completely over or am i living in cloud cuckoo trying to get the car to be able to turn completely over?
thanks rhid
#2 PoolGuy
PoolGuy
  • 981 posts
Posted 08 May 2022 - 05:36 PM
Maybe I'm missing something too, but surely the bar that goes to the subframe needs to be triangulated so that it'll support the car?
#3 weef
weef
  • 557 posts
Posted 08 May 2022 - 05:59 PM
I am afraid just looking a the geometery of the bars that will never turn. The tubes have to be parrallel with to the axis of the vehicle to rotate. It is start again time and redesign it.
#4 Spitz
Spitz
  • 1,716 posts
Posted 08 May 2022 - 06:09 PM
Looks like the top of the triangle is the weak point
#5 imack
imack
  • 2,382 posts
Posted 08 May 2022 - 06:17 PM
I agree with weef, you're never going to be able to rotate that!
#6 imack
imack
  • 2,382 posts
Posted 08 May 2022 - 06:18 PM
Double post
Edited by imack, 08 May 2022 - 06:18 PM.
#7 MacGyver
MacGyver
  • 1,028 posts
Posted 08 May 2022 - 06:20 PM
Triangulation is the key, you've only bolted it to one axis and all the weight is going thru them. Like taking out a nail with a crow bar, no matter how big the nail the leverage is too strong without another point.
On the rotisserie without a pole it picks up near the subframe lower points at the front and parcel shelf at the back.
Good old auto correct...
Edited by MacGyver, 08 May 2022 - 06:30 PM.
#8 MacGyver
MacGyver
  • 1,028 posts
Posted 08 May 2022 - 06:28 PM
Attached File  _20220508_202334.JPG   31.29K   6 downloads
You can see the front bracing on these pictures.
Attached File  _20220508_202356.JPG   41.6K   5 downloads
And the back on this one.
Attached File  _20220508_202440.JPG   68.72K   4 downloads
Sorry I don't have better ones but I can't find better ones to hand, but plenty on the net if you want. 😁
Ben
#9 rhidmogz
rhidmogz
  • 21 posts
all the weld etc are fine nothings broken
i get the car wont turn as is atm my question is why does it seem to be sitting as it is ive coppied the look from jigs ive seen on line
could it be down to the strengthening bar not being enough and the triangle and need two feet that extend?
#10 rhidmogz
rhidmogz
  • 21 posts
Posted 08 May 2022 - 06:30 PM
Ben
 ahh right i can see what ive not done now!
in the photos ive been looking at ive not notice these extra joists
thanks ben!
#11 MacGyver
MacGyver
  • 1,028 posts
Posted 08 May 2022 - 06:33 PM
I can get better ones if you'd like?
But if you bolt a plate on the toeboard and then a bar to the pole from each side you should be fine.
#12 PoolGuy
PoolGuy
  • 981 posts
Posted 08 May 2022 - 06:40 PM
Basically the bar needs three contact points, whether two are on the car and one on the jig or vice versa doesn't matter, but without massive strength it won't work as you have it. MacGyver's pics show a good example.
#13 rhidmogz
rhidmogz
  • 21 posts
Posted 08 May 2022 - 07:06 PM
their great thanks!
i can understand it in my head now a little tweak in the week and it should be good thanks guys
#14 Aly-g
Aly-g
  • 460 posts
  • Local Club: Still looking
Posted 08 May 2022 - 07:47 PM
I'm in total agreement with weef, there is no way that's going to rotate ,the tubes do have to be parallel, as soon as you try to rotate the car the tube on the A frame will try to turn the whole frame and not the car.  time to get welding.
Allan
#15 postma
postma
  • 41 posts
Posted 09 May 2022 - 06:59 AM
some pictures as reference ...
