The Wheels On My Mini Go Ve-vum Ve-vum Ve-vum Ve-vum
#46
Posted 11 March 2009 - 03:54 PM
#47
Posted 11 March 2009 - 04:01 PM
I am printing all this out & I will discuss this with the garage once I have done Guessworks's lil diff test.
Edited by Juju, 11 March 2009 - 04:03 PM.
#48
Posted 11 March 2009 - 04:12 PM
#49
Posted 11 March 2009 - 04:17 PM
Don't you also have a complete donor Mini in cardboard boxes to borrow bits off? It'd be cheaper than dinting the piggy bank for new bits when you ain't defo isolated the cause yet.
He's not a donor mini Ethel
If I can determine whether it is deffo the diff, then there's no point in me touching the driveshafts at the moment. The bearings are now fine & smooth....but for how long, I might ask.....
#50
Posted 11 March 2009 - 04:25 PM
#51
Posted 11 March 2009 - 04:28 PM
unlike people Minis can have their lent bits back anytime 'n if you can't drive the whole Tommy one of his hubs is a small step in the right direction
Yeah, I know. She had a new hub last time though. See post #17 of this missive.
#52
Posted 11 March 2009 - 05:36 PM
#53
Posted 11 March 2009 - 06:35 PM
Mr Guessworks: The results of your lil test are as follows:
I followed one of the marks on the tyre wall through 1 and a quarter inches of play. Without drawing a complete clock-face or compass on my tyre in the works carpark, I think that roughly translates as between 7 and 10 degrees of movement.
Bad news?
#54
Posted 11 March 2009 - 06:41 PM
#55
Posted 11 March 2009 - 06:46 PM
When the munched bearings are taken out, are both sides munched? If something is munching the bearings then possibly it could be the wheels (haven't got big spacers have you?), maybe the brakes in some way?
Or quite possibly mechanic error. It would be odd that you have two defective hubs that are munching bearings.
Well the set of bearings last year, only the inner part was munched (same side: O/S). I don't know about the last set. I'll have to ask...I've not ruled out mechanic error, but they've not had the same problem with another car....
#56
Posted 11 March 2009 - 07:00 PM
She's on 12"x5" (if you care to read the thread
Bad news?
I don't think that is excessive JuJu...............
#57
Posted 11 March 2009 - 07:01 PM
#58
Posted 11 March 2009 - 07:18 PM
Firstly apologies for the dodgy camera work, using phone and only one hand...
The first video is of the inside of the differential, you will see the pinion gear or planet gear moving up and down
http://www.guess-wor...11032009014.mp4
the second shows the equivalent deflection of the output shaft as if you were turning the driveshaft, the mole grip is a 9" grip so the end of it is not dissimilar to the radius of a 13" wheel and tyre... When the grip is down, that's it's full extent of movement before the diff turns so the movement you see there is the total 'slack' in the diff.
http://www.guess-wor...11032009015.mp4
For reference... The diff pin in that is fubar...
I'll be build a new diff tonight with new pin and planets etc... I'll so the same video's for that when it's done to show the DIFFerance
#59
Posted 11 March 2009 - 07:27 PM
#60
Posted 11 March 2009 - 07:39 PM
