1986 Mini City E - Lime Green 1293Cc
roundnose
293 replies to this topic
#61 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 17 August 2012 - 05:39 AM
ordered a tyre, so will have had 4 new tyres just about.
Ordered aload of stuff for when the respray happens and hopefully buy the paint today.
- headlamp bowl gaskets
- door handle gaskets
- boot hinge gaskets
- white seam sealer (tiger seal) to apply in panel joins (white so it doesnt darken the paint when applied over top)
- check strap seals
- reflective stick on front reg plate
- etc
will try and get two wheels shot blasted tomorrow and painted on sunday.
#62 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 18 August 2012 - 06:37 AM
Paint bought yesterday, along with stonechip, dolphin glaze, sanding discs etc. Got everything now, just need september to hurry up.
Jordie
#63 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 19 August 2012 - 02:32 PM
well had a go at repairing and painting my wheels.
in hindsight, i should have spent more time working on the kerb rash. on the big areas i used chemical metal, worked fantastically. I left the smaller marks, hoping the primer and paint would fill them, but it hasnt, but its nothing major really.
I aint no painter, i can just about get even coverage on a flat panel so obviously a minilite alloy wheel wasnt ideal for me to paint, but heres some photos. Its abit orange peel in places, but hopefully i can polish the rims up for a smoother finish.
On this photo, you can see the edge with its little marks. i will chemical metal any marks on the next rim. This has had another coat of paint since, as the paint didnt get good coverage between the spokes.
#64 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 19 August 2012 - 02:35 PM
Heres some more pics, its quite shiny even with the orange peel so hopefully will buff up even better.
Hardly any dust in it either and was painted outside.
#65 Roach
Roach
  • 58 posts
Posted 21 August 2012 - 02:45 AM
Wow. Shiny!
#66 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 August 2012 - 05:40 AM
messed them up. left them on a table to dry, stupidly.....they stuck to the table abit. So i sanded back the back and resprayed, giving the fronts a thin coat to cover overspray from the back, then i seen a run.....DOH
Its hard to paint them hanging up due to runs, but if you place them down on a table etc, the paint sticks to the surface.
Might get them powder coated if cheap enough. Anyway, its all experience....paint mixing, spray gun setup etc.
#67 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 August 2012 - 04:43 PM
silicone HT leads on order. one of the leads is sparking across to the dipstick or engine block. temp repaired with insulating tape while new leads are delivered.
#68 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 23 August 2012 - 05:03 PM
HT leads arrived, got a new set of plugs too just incase.
Job for tomorrow i think.
Jordie
#69 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 25 August 2012 - 02:54 PM
picked up a windscreen from minispares north today, for after the respray.
#70 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 26 August 2012 - 06:01 PM
somewhere close....Attached File  MiniSelectagreen.jpg   124.21K   2 downloads
#71 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 August 2012 - 07:22 PM
finally got new orange plug leads fitted, running a tad better now. Car was parked up all weekend, was nice to use it again today.
#72 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 August 2012 - 08:16 PM
flushed and rebled the brakes, pedal alot better now.
was going half way with no resistance, then solid.....its disc brakes, no servo. pedal is alot better now, firm from the top and stops well.
#73 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 08 September 2012 - 08:19 AM
Only a couple of weeks till paint time.
Ive had an oil leak since I bought the car, NS of the engine. So ive ordered the gaskets to go behind the engine plate and the timing cover. Ive ordered a new timing cover as I find most of time they leak due to been bent by over tightening. New seal etc too.
I am doing this at home next weekend i think, if i can get space in the garage.
Going to do the gear linkage seal aswell, just for good measure.
Jordie
#74 mike.
mike.
  • 6,176 posts
Posted 08 September 2012 - 08:43 AM
Sounds like your collecting a nice selection of bits and bobs for it - Shame about the wheels though the finish looked great!
I had to spray mine twice as well before I got them right!
#75 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 08 September 2012 - 08:45 AM
havent got around to re-doing the wheels yet. may end up getting done when the car gets painted in a couple of weeks. Though speaking to the painters at work, they said i havent done bad as gloss black is hardest to paint due to the shiny finish....id got too much paint in places and too little in others.
Need to finish prep on the reskinned door ive done and sort out all my gear ready for the respray. Need some more supplies actually....another trip to the paint shop.
Jordie
