Posted 12 March 2013 - 05:39 PM
engine 1000 i bought it 2 months ago i need help because when i'm driving and the rpms reaches 3000 it starts to backfire and the rev gauge goes crazy ... can someone help me out !
what can be the problem
i checkt the distributor but it looks fine (clean it )
here is a video of the problem the sound its not good beause cell phone hits the steering wheel
Posted 12 March 2013 - 05:43 PM
Posted 12 March 2013 - 05:45 PM
Posted 12 March 2013 - 06:53 PM
Posted 12 March 2013 - 07:03 PM
Judging by the fact your rev counter appears to lose its "signal" at about 3000rpm (needle dropping sharply) I would say it's an ignition problem.
If your distributor has points/condensor I would check the points gap and try another condensor. If its got electronic ignition it might be the amplifier module breaking down at higher revs.
I had a similar problem a few years back, and that was the coil winidings breaking down. I'd tighten the coil clamp too much and it punctured the bodyof the coil and caused a short from the winidings to the clamp. This showed up as a mis-fire around 4000rpm!
Hope this helps!
Steve.
Edited by Stevie W, 14 March 2013 - 06:01 PM.
Posted 12 March 2013 - 07:37 PM
Posted 12 March 2013 - 08:01 PM
Posted 12 March 2013 - 10:01 PM
Posted 12 March 2013 - 10:05 PM
You can check the coil resistance with a multimeter but so many times it has proved nothing..
Edited by jaydee, 12 March 2013 - 10:06 PM.
Posted 13 March 2013 - 03:15 PM
Posted 13 March 2013 - 04:22 PM
Do not start with the coil. Take Jaydee's (and others') advice and go through the points and condenser first. Always start with the cheap stuff. Save the coil for last.
While you are working on the items inside the distributor, take a close look at any flexible wires going between the breaker plate and the distributor housing. Some use an earth wire between the plate and the dizzy housing. If this fails you can get weird ignition problems. If you have points there will also be a wire from them to the "outside". If that wire breaks the ignition system will stop working. In both cases, the problem may not show up until the advance mechanism starts to kick in.
Posted 13 March 2013 - 09:24 PM
Posted 14 March 2013 - 08:15 AM
thanks for the help ! everyone
Posted 14 March 2013 - 09:25 AM
Posted 14 March 2013 - 10:51 AM
thank for the video !
super mini mad.
Mini Technical Sections →
Problems, Questions and Technical →
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
Su Carb Backfiring/spitting FuelStarted by Adge456 , 25 Jul 2026 |
Main & Be Bearing AssemblyStarted by RCrossley , 11 Jul 2026 |
Head Gasket Or Tappet Cover Oil LeakStarted by crbeasley01 , 25 Jun 2026 |
