Posted 13 March 2013 - 03:10 PM
Any help appreciated.
Posted 13 March 2013 - 03:14 PM
Posted 13 March 2013 - 03:15 PM
Posted 13 March 2013 - 03:21 PM
It would suggest there's a problem with the Top and Reverse clutch engaging, but that is simply eye-balling from your original post.
Posted 14 March 2013 - 12:19 AM
Does it do this in D (auto) or if you use the manual and go from 3rd to D (4th) ?
How exactly are you checking the level ?
This is very important and often done incorrectly.
Posted 14 March 2013 - 12:21 AM
Tie up is probably best described as similar to applying the handbrake :-(
Posted 14 March 2013 - 04:35 PM
Posted 14 March 2013 - 09:27 PM
Posted 14 March 2013 - 09:41 PM
Posted 14 March 2013 - 09:51 PM
Martin will be along shortly to tell you all the bad news
Posted 14 March 2013 - 10:50 PM
If you change using the "stick" it goes into top ok without flare ?
But in auto mode it flares into top ?
Is that correct ?
If so it is most likely avalve body issue, remove, partial strip (NEVER PERFORM A FULL VALVE BLOCK STRIP) and clean in parafin, change the parafin and clean until it runs clear, use a tooth brush and do NOT turn it over keep the clips to the top, only remove the top cover, seperation plate don't loose the little flat steel valve, I'll try to add some photos.
Edited by mra-minis.co.uk, 14 March 2013 - 10:52 PM.
Posted 14 March 2013 - 10:53 PM
Posted 14 March 2013 - 10:54 PM
Posted 14 March 2013 - 10:55 PM
Edited by mra-minis.co.uk, 14 March 2013 - 10:57 PM.
Mini Technical Sections →
Problems, Questions and Technical →
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
Su Carb Backfiring/spitting FuelStarted by Adge456 , 25 Jul 2026 |
Main & Be Bearing AssemblyStarted by RCrossley , 11 Jul 2026 |
Head Gasket Or Tappet Cover Oil LeakStarted by crbeasley01 , 25 Jun 2026 |
