Planning on fitting a sump guard that I got for 99p on ebay and a oil cooler, I was just wondering if I got a water temperature gauge with numbers would it be okay to read oil temperature if I used a normal water temp sender in the gear box?
Posted 25 August 2014 - 01:51 PM
Posted 25 August 2014 - 01:58 PM
Can't see why it wouldn't work. Oil temp will be higher than water temp though
Posted 25 August 2014 - 02:11 PM
I realized this would be the case, that's why I thought I would be better of getting a numbers one as they seem to have a higher reading. Proper oil gauges seem a little expensive.
Posted 25 August 2014 - 05:43 PM
Amazon servers me well when buying gauges :)
Mini Technical Sections →
Problems, Questions and Technical →
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
Su Carb Backfiring/spitting FuelStarted by Adge456 , 25 Jul 2026 |
Main & Be Bearing AssemblyStarted by RCrossley , 11 Jul 2026 |
Head Gasket Or Tappet Cover Oil LeakStarted by crbeasley01 , 25 Jun 2026 |
