#211
Posted 18 January 2013 - 09:57 AM
#212
Posted 18 January 2013 - 05:05 PM
What paint did you use on the engine?
#213
Posted 18 January 2013 - 05:15 PM
and black engine paint used on motorcycles (granville i think).
#214
Posted 20 January 2013 - 06:41 PM
Some wiring for spotlamps done
radio wiring done
tuned mixture/idle, bled coolant system.
ordered some new grease nipples and grease gun as mines fudged.
#215
Posted 22 January 2013 - 05:31 PM
New front clear indicators here. modern type with screw type lens as my current ones arent brilliant.
New red coloured bulbs for rear brake/tail light.
#216
Posted 28 January 2013 - 06:40 AM
only bought a 1275 rad bracket at bingley and some vinyl etc for making dashboards.
Hopefully get abit of mot prep work done tonight.
#217
Posted 29 January 2013 - 06:49 AM
Also undersealed, fitted grease nipples and greased it up.
Rear brakes adjusted up.
Exhaust brackets adjusted to stop "blow" at Y piece.
Grill refitted and wiring improved.
Bonnet wont seem to click down properly, i may have caught the slam panel when taking engine out, so need to adjust either the panel or bonnet pin to suit.
Mot either later today or tomorrow.
Need to change rear indicator bulbs as flashing white and rear fog light bulb isnt very red, but that will be sorted this morning.
#218
Posted 29 January 2013 - 11:52 AM
#219
Posted 29 January 2013 - 12:43 PM
#220
Posted 30 January 2013 - 02:24 PM
#221
Posted 30 January 2013 - 07:33 PM
got to change seal n diff side casing at weekend to fix that. casing is the problem, i should have changed it when i had the gearbox on the bench, looks like someones been at it with a chisel to remove the seal in situ.
advised on rear reflectors and a tiny bit of play in a balljoint.
So overall quite happy, need to pickup a seal/gasket for the diff casing tomorrow. allready got a replacement casing to go on.
Jordie
#222
Posted 02 February 2013 - 03:12 PM
Obviously changed oil, so now its got fresh 20w50 halfords classic. Anti freeze checked again....OK. Retorqued the head and need to adjust tappets next time.
Now can move onto the bonnet and interior bits and bobs.
Jordie
#223
Posted 12 February 2013 - 04:40 PM
Got a bonnet that needs shot blasting and painting etc, but havent found time to do it yet.
Jordie
#224
Posted 16 February 2013 - 06:56 PM
Probally fit the new front indicators and rear seat belts tomorrow, subject to having the correct bolts.
#225
Posted 16 February 2013 - 08:56 PM
Also, is there another green Mini that parks at the NERC? I always think it's yours.
Projects →
Mini Saloons →
1976 Mini 1000 Le "stripey"Started by cafeclassic , 03 Sep 2025 |
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 |
This topic is locked
