Smokey 1098 Engine
engine
21 replies to this topic
#16 Cooperman
  • 23,569 posts
Posted 04 December 2020 - 10:10 PM
Let's consider two more unusual thngs.
1. Does it have a servo? If it does, it could be brake fluid burning due to a leak in the servo unit allowing the fluid to leak into the induction (vacuum) area. .
2. Is there any chance it could be steam? I know it sounds unlikely and I'm sure you would have thought of this, but thought I would mention it. A small crack in the head in the exhaust tract area could let a small amount of coolant into the hot exhaust area.
#17 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 04 December 2020 - 10:14 PM
There's no substitute for an Italian Tune Up to find out whether this is a temporary problem, or not. Get it out and make it sweat.
Edited by Quinlan minor, 15 December 2020 - 01:26 PM.
#18 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 05 December 2020 - 10:37 AM
There's no substitute for an Italian Tune Up to find out whether this is a temporary problem , or not. Get it out and make it sweat.
agreed, you need to drive it somewhere. you need to run it under load.
#19 Maccmike8
Maccmike8
  • 1,101 posts
Posted 13 December 2020 - 04:11 PM
#20 Maccmike8
Maccmike8
  • 1,101 posts
Posted 13 December 2020 - 04:12 PM
Turns day to night  :ohno:
#21 bpirie1000
bpirie1000
  • Area Managers
  • 2,567 posts
  • Local Club: Amoc
Posted 15 December 2020 - 02:00 PM
Chuffing brilliant
#22 peasoup39
peasoup39
  • 97 posts
Posted 24 March 2021 - 06:12 PM
Finally got around to removing and stripping the engine. Good news is everything was normal except the rings were very sharp on the edges which my engine guy picked up immediately. Crank and all bearings good, bores and piston all good.  I was advised by several people that rings were an issue ion these engines but am surprised that worn rings could produce this much smoke. Still not complaining this will be a relatively cheap rebuild. Hone the bores, polish the crank, new bearings all around and a new oil pump. Whilst apart fitting hardened seats so may change guides and definitely the stem seals. Happy days.
